跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
577 个问题 查看全部
Home button not working after USB Charge Port Replacement
My friend has 2 Galaxy S5 phones. One is a G900A and the other a G900T. He replaced the USB Charge port on both. On a GS5, the charge port is on a daughter board which also houses the home button and soft buttons. For some reason the soft buttons work but on both the home button no longer works. Even the original ones he had don't work anymore. I took a look at it, and I couldn't see anything wrong. I even double checked the iFixit guides. We also had the seller of the parts resend replacements and bought another from a different source. All have the same problem. Does anyone have any idea?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
@avanteguarde
I've noticed you've been inactive the last few days. Something wrong?
I will find you. I will fix you.
Ifixit play on Leon Neeson
完成的
Samsung Galaxy S5 Teardown
See steps 6 and 12 for insight on the home button and its cable. That's the best I've got to offer.
完成的
@pccheese, Internet problem. Windows 10 updates will swallow your bandwidth whole!
完成的
Are you on DSL? We've got 6 windows 10 PCs and we never have a bandwidth problem. You've been out for days!
完成的
Yeah, DSL. Try running 10 Windows devices on that! Especially with the creators update coming.
完成的
显示更多的1条评论
添加一条评论
1个答案
The home button on the galaxy s5 connects directly to the MB if I remember correctly. Double check the integrity of the board side (female) connector; if the home button got pulled out without being properly unplugged it could be causing the issue.
这个答案有帮助吗?
得分 0
1条评论:
@xela, no, the home button is part of the charge port daughterboard along with the 2 soft buttons. The soft buttons work, but the home button does not. The chargeport has been change 2-3 times from different sources, but the home button still does not work.
完成的
添加一条评论
添加你的答案
S W 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 762
