Digital display not showing
The display is not showing when you bake nor show the temp. but it works fine.
@hils , enzweilerswho ,The display could be faulty. You could try unplugging the oven and remove the display and check all the connections and clean them. While apart check for any loose/damage/corroded/burnt wires or components.
If display does look to be at fault you could try to google search for replacement part using your make, model#,display. Good luck.
这个答案有帮助吗?
@hils , enzweilerswho, Here is a link to what I beleive may be your manual, did not see anything on error codes, but manual may be of some help. Good luck.
Thks for your advice. It popped up with this error code. where can I find out what it
means. I dont even know the model nbr. Check under and sides and nothing.
这个答案有帮助吗?
Hi,
Can't find what the error codes mean but in a way it is good news. At least the display is working (of sorts).
Interesting that there is no model number anywhere on the oven. Searched for B&D countertop convection ovens, found them, but yours must be a superseded model as none looked the same as yours (at least not the control panel anyway). Check the control board for a board number printed on the board. Try searching online using just the number and see if there are any results. Sometimes with a bit of luck the model number is to be found somewhere on the inside of the cabinet.
Be safety aware! When (if) you dis-assemble the unit ensure the the power is always totally disconnected whenever the oven controls etc are exposed.
As 'bake' is not the only option, does the display work correctly when selecting any other option e.g. cooking? If it does, perhaps you could check the connections leading from the 'bake' button. I assume that it is just a non locking push button and not a locking type i.e. push to operate, push to release. Is it the only function that shows the temp? If so perhaps the temp sensor is faulty therefore no reading.
过去的24小时: 0
过去的7天: 4
过去的30天: 16
总计 1,392
