跳转到主内容
加入维修社区 - 创建账户
Logitech M305 是一款于 2010 年发布的无线鼠标。它采用对称式设计,左右手均可使用。
What do I do when the battery is not held tightly enough in the mouse?
This is the second of these mice I've had and it is already, after only 2-3, months showing the same problems I had with the first. The spiral portion of the battery holder is compressed and does not hold the battery snug, leaving me with no curser response. I have tried pulling it out more but it seems to have a 'memory' action and is just compressed again when the battery is reintroduced.
I love the size of this product and would rather not have to go to a full sized mouse, but if I have to go to another product I will. This is annoying!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
One solution is to fold up a piece of foil to fit between the gap. It's not the best solution, but it usually works just fine. It's just annoying when you have to replace the battery, and the foil falls out as well.
完成的
Great idea, thanks. Maybe I can extend the foil up the side of the battery, thereby make a "cap" or selotape it on.
完成的
添加一条评论
1个答案
已选择的解决方案
You can use one of those button batteries used in hearing aids to buffer the space. I am not sure which one fits though.
这个答案有帮助吗?
得分 2
12条评论:
Hi @avanteguarde ,
Wouldn't that add or subtract to the voltage supply from the battery, depending on which way round it was? Being in series with the main battery.
完成的
@jayeff, forgot to mention it doesn't have to hold a charge, just close the circuit. You just want something about the same size to buffer the space.
完成的
sandhd, if you have the receipt still, and its less than 3 years, Logitech will just send you another one free of charge, and you can keep the broken one.
完成的
Hi @avanteguarde ,
Agree to disagree.
Usually a hearing aid battery has +ve face and -ve case. So even if hearing aid battery is flat (voltage wise), the -ve case is touching the spring and the +ve face is touching the main battery or vise versa. Can't see how the case could be touching both. The main battery current is still flowing through the battery not through the case of the battery. Effectively through an unnecessary resistance. Perhaps it would be betterto use an appropriately sized small steel nut or steel washer
完成的
I am a little confused at your comment. When you put 2 batteries in a flashlight, the plus end touches the minus end of the other, no?
完成的
显示更多的7条评论
添加一条评论
添加你的答案
sandhd 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 35
总计 7,237
