How do I reposition the spindle of my hard drive on my laptop
whenever i boot up my laptop, the hard drive clicks 8 times. and im positive that it is because the spindle is stuck, and needs to be repositioned... and im wondering hwo to do that
You can't fix your drive without having a clean room as any dust allowed in will kill the drives heads.
At this point its best to just replace the drive.
这个答案有帮助吗?
If it clicks 8 times on turn, it doesn't mean the spindle is stuck. It means there is an area of hard drive frequently accessed on a start up that it is having problems reading. 8 clicks or so means its retrying to re-read.
It is strongly suggested you replace the hard drive. It may even be a good excuse to get one those new fangled SSD drives.
这个答案有帮助吗?
K... should I get m.2, pciee, or sata 3? Considering it's a laptop... I'm thunking data... but I'm not sure how I would install the m.2 or pci ssd
Hi @marko1 ,
Look up your exact laptop specs to determine what type of HDD connection it has. You may only have the one option
Can you get the model number from device manager? I can tell from that.
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 173
1条评论
Spinning disks are typically 2.5" using a SATA connection. Without knowing what your system is we can't guide you any further.
由 Dan 完成的
