跳转到主内容
Released in March 2013, identified by model number S500CA-SI50305T
How to use with blank hard drive
Hello,
I just bought an asus s500ca without a hard drive is there anyway if I just pop in a new hard blank drive and it will work? will I have to install windows?
any help is appreciated thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
The blank drive will not work until an operating system is installed. Usually the OS install will prepare the drive by formatting and partitioning before installing the OS.
完成的
Thanks for the response!
If I make a bootable usb on my current computer will I be able to install a ssd on the new computer then boot it up with the usb and then run windows on the ssd?
完成的
添加一条评论
1个答案
已选择的解决方案
@bradb922, check to see which version of Windows originally came with that computer. There is a certificate of authenticity with a Product Key on the bottom of the laptop if it is Windows 7.
If it originally came with Windows 8, there may be no sticker. If this is the case, your life is easier.
Go to Microsoft's website and download their media creation tool. It is available for Windows 7, 8.1, and 10, but Windows 7 you need to enter a key. Use this utility to download and create a bootable USB. If the hard drive is correctly installed, the USB will be able to format and install Windows on to that hard drive.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Brad 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 585
