跳转到主内容
加入维修社区 - 创建账户
2014年9月19日发布的iphone 6 Plus有着比iphone 6大的5.5英寸屏幕。
My phone won't turn on, whats wrong?
A year ago, my phone was cracked and stopped working and I tore the phone apart. I recently got energetic and put the phone back together. The screen worked and I could tell the phone was on. I ordered a replacement screen and after replacing it, the phone worked! I had charged the phone to 2% and figured I would charge it later when I got into class. The phone died, and ever sense then has not been working. I double checked the cables to make sure the screen was in right and everything was fine. It was. I don't even get a vibration when I plug it in to charge, or even if I try to turn it on.
What could possibly be my problem?
Also, the phone connects to itunes and I've tried the hard reset, recovery mode, etc. Nothing seems to work!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
So it seems like the motherboard and charge port are working since iTunes does recognize it. It could be possible that the display is faulty or something cause a short.
完成的
添加一条评论
2个答案
已选择的解决方案
Sounds like a faulty screen if iTunes recognizes it. Shine a bring light up to the screen and see if you can see a picture.
这个答案有帮助吗?
得分 3
1条评论:
I tried this, however, no picture was seen. But, I also don't know for sure if the screen is on to begin with.
完成的
添加一条评论
Cody McCarty , Maybe double check battery and charge port connections for loose/damage/corrosion, clean and reseat battery connection, look inside charge port and use a can of compressed air to blow out any dust/debri.. Remove battery then reinstall and try charging. It sounds like you may have a faulty battery or charger, Try a different charger/ cord and see if it takes a charge. If not change the battery. Good luck.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Cody McCarty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 169
