跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Optical Drive seems to be making more noise?
My optical superdrive seem to be louder than it was before when inserting and removing disks. It sounds really mechanical and when you compare it to a different macbook it seems quite loud. It is a late 2006 model - is this normal?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Look at the drive slot - is it smiling at you? If so, then the noise is probably coming from the disc rubbing again the plastic of the case. It is common for this area to become deformed, as the plastic is thin here. The primary cause seems to be carrying the macbook around open, squeezing down over the optical drive area.
If you still have AppleCare on this unit, I would take it in to an Apple Store or AASP to have the drive replaced.
If not, you can try to carefully work the plastic back to its normal shape using a wooden tongue depressor, or other fairly soft tool - DO NOT USE METAL! Only work the plastic, do not go in and deform the metal drive mechanism itself.
Good Luck!
这个答案有帮助吗?
得分 3
1条评论:
Will it do any damage if I leave it as it is?
完成的
添加一条评论
it happens. more frequently than not. Buy a new drive and replace it, its fairly easy to do... try davids methods, and if that doesnt cut it, replacing it is a walk in the park
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
AussieMac 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,322
