跳转到主内容
加入维修社区 - 创建账户
GoPro Hero5 Black是GoPro于2016年10月发布的高清防水运动相机。具有4k分辨率录制和语音控制,触摸屏显示和内置WiFi功能。
The LCD screen has a hairline fracture
I purchased my GoPro about a month ago - and the GoPro Hero LCD screen has a hairline fracture! I just took it out the case after using it - and the crack appeared. I did not drop of doing anything that would impact the camera. Has anyone else had this issue? and or know how to repair it or warranty the camera?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
Is it still waterproof
完成的
添加一条评论
3个答案
最有帮助的答案
Are you sure it's cracked? And is everything on the LCD still visible?
这个答案有帮助吗?
得分 1
2条评论:
100% cracked. LCD still works fine
完成的
@jezza even if it is cracked, if it is visible I wouldn't worry about it. But if it develops black spots then replace it. Even if you replace it it would probably still be pretty expensive as the device is still new.
完成的
添加一条评论
Where could i go to get it replaced?
这个答案有帮助吗?
得分 0
添加一条评论
I noticed mine was cracked this evening too. Hasn't been dropped or abused in any way. I think this is a protective glass over the LCD screen, since the LCD screen still seems to work fine.
Would be interested know how I go about getting it fixed.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jezza 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 10
过去 30 天: 18
总计 4,531
