跳转到主内容
这款4.7英寸iPhone于2014年9月19日发布,是iPhone 6 Plus的缩小版。
4994 个问题 查看全部
Touch Screen Non responsive
Working on a phone and replaced the screen due to it being cracked. Screen comes on as expected just not responding to touch. Was able to get it to work a couple of times before by restore but now nothing is happening.
Any help would be appreciated.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
tried putting a new screen on it ?
完成的
Yes, to no avail. I think it is the Touch IC issue.
完成的
添加一条评论
2个答案
已选择的解决方案
If you tried a different known good screen, then you probably have a failing touch circuit, and the touch ICs being the most likely (though not the only) suspects.
Search for "iPhone 6 Touch Disease" and you'll know what I mean.
Unless you broke the connector or pried something off the board, you have no responsibility whatsoever in this failure.
Because if the touch ICs themselves are failing, the reason is probably repeated drops or bends or sitting while the phone is in the back pocket. And/or the drop that caused the screen to shatter triggered or worsened the issue. All this caused the touch ICs to have connections that separate from the board, causing intermittent failures then no touch.
The most durable fix is to replace or reball the touch ICs, while repairing any potentially weakened traces. Then reinforcing the frame of the iPhone board to make it less prone to flexing.
This repair is certainly doable as any respected technicians has seen a lot of them.
But it certainly is not for a DIYer since you'll need very specialized tools and excellent control and skill to repair it. The touch ICs are packed close to a lot of critical components, and the other side of the board is populated by the CPU. Extreme care must be taken during the repair.
Some people place shims or electric tape between the board and the housing, to press the touch ICs onto the board.
This may constitute a temporary fix at best, but we've seen that it often results in failures that are harder to repair. This pressure is causing extreme stress on the board and causing traces to brake and more failures to happen.
这个答案有帮助吗?
得分 5
1条评论:
Thanks. This makes sense since I tried a Known Good Screen.
完成的
添加一条评论
There are couple of things that could be happening, first check the connectors on the screen and logic board to make sure you haven't damaged any of the pins. If they are undamaged then check to make sure the digitiser connecter is being correctly inserted into the board connector. If there is no damage and the screen is correctly connected then you may have a faulty screen.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jonathan 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 287
