跳转到主内容
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
33 个问题 查看全部
Why do my windows drop into my door with every bump?
It seams as though every time I hit a bump, my rear two windows drop further and further into the door. The window switch to raise the windows make a sound as if they are working but the windows don't seem to catch and raise up. Once parked, I have to use my hand to press against the window and raise it up myself. Besides using cork screws to hold my windows in the closed position, how can I fix this issue?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@drocker127 , Dineen , The window regulators/tracks/cable that raise and lower the window off the power window motor have broken and probably need replacing. There was some what of a design flaw in these parts, making them weak, which I believe may now be improved. See links below to see regulator replacement video. The new part can be found at any automotive supply shop, try a few to get better pricing or try ordering online after doing a search on line from a reputable site. If not comfortable doing repair, have a good Tech. have a look and estimate repair. Good luck.
https://www.youtube.com/watch?v=Nzavs8rA...
https://www.youtube.com/watch?v=Tv2Uq2oi...
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Dineen 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 649
