跳转到主内容
加入维修社区 - 创建账户
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
It doesn't start anymore.
Hi pals,
First I would like to apologyse for my bad english.
My daughter put water on the keyboard.
Once dryed, the comp didn't restart.
My brother cleaned it with special cleaning products and the mac book pro starter once.
We think the problem comes from on/off button but before dissasembling allé the parts, we would like to be sure of it.
Is there any pin I can use to "emulate" this button ?
Kind regards,
Jonathan.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Ok mine is 820-2565-A but I didn't found any pic about these pads :(
I also found oxydation :/
完成的
That code refers just to the small magsafe connector board, that is used by a wide range of models. The code you have to look for is not as evident and it's on the logic board. You might need a good light source to find it and a magnifier might help as well. A little oxydation might not be that bad given it's at least a 5 years old machine, providing it's not corrosion.
完成的
添加一条评论
1个答案
已选择的解决方案
Yes, the are power pads for testing purposes on the logic boards. If you look carefully you should be able to find a printed number starting with 820-xxxx-x that indicates the exact model you own. When you have that, a search on the net including number and power pads should answer your question.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
urbain.des-bois 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 83
