跳转到主内容
加入维修社区 - 创建账户
Mac mini 最初于2005年1月发布。
Model A1176
Need new hard drive. Can you furnish drive and instructions for installation. Tried previously but failed. Want to try again. Due to defective HD cannot boot up mini and consequently cannot provide data re speed, etc.
Will you show hard drives available and detailed instruction manual for installation.
Refer to our 127039 where I purchased hard drive and tools. Neither hard drive nor instruction book were correct ones for my model mini.
Want to try again. Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Can I get a copy of the detailed instruction manual? I tried printing from your web site but the colors are so faint they are difficult to read. My order number for the hard disk is 130963 dated 12/28/09. If instruction sheets could be sent with order that would be great.
Thanks and wish me luck.
Joe Clark
完成的
Unfortunately, that order has already been shipped out. Here's links to hardware installation and software installation. The PDFs of the guides are designed to be printed so they should look fine. Is the problem you're seeing something with the PDF?
完成的
添加一条评论
2个答案
已选择的解决方案
If you have a Mac mini that's model A1176, you'll need a hard drive that's a 2.5" SATA drive.
Here's some drives that would work with your machine (there are others, these are just a few):
  • 320 GB 5400 RPM SATA
  • 500 GB 7200 RPM SATA
  • 640 GB 5400 RPM SATA
Here's a link to the installation instructions
If you need to return a part, just send an email to our support team and we'll get you set up with an RMA.
这个答案有帮助吗?
得分 3
添加一条评论
Gentlemen,
I do not want to return a part but I do need your help. I sent you an e-mail yesterday but do not find any evidence that it was actually sent.
I removed the bad hard disk from my Apple MIni but installing the new one turned out to be well beyond my capability. Question: Do you do repair work? If I sent the computer to you, minus the defective hard disk but with the new hard disk purchased from you recently (Order 130963, 12/28/09) enclosed would you install the new hard disk? If you do this sort of thing, how much would it cost and how long would it take?
Any special requirements on sending the computer to you? Any ID numbers required, to what address should it sent to? Look forward to hearing from you. I will send you a check or reference to a credit card when I hear from you.
Joseph T. Clark
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JoeTrudy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 1,863
