跳转到主内容
加入维修社区 - 创建账户
iPhone 6s Plus 发布于2015年9月25日,有两个型号A1687、A1634,网络制式有GSM、WCDMA,存储容量有16GB、64GB、128GB可选,机身颜色有银色、金色、深空灰、玫瑰金。维修iPhone 6s Plus和前代产品相似,需要螺丝刀和撬棒等。
Back camera doesnt work even after replacement
I bought this phone for what i thought would be an easy fix n flip.
The power button and back camera werent working.
I replaced both parts. However, while doing so, much to my horror I noticed the phone was water damaged. Replacing the parts fixed the power button, but the back camera still doesnt work.
The u3200 chip and that area had a slight bit of green corrosion, so i cleaned it gently with alcohol.
Nothing appears damaged, burnt, or exposed, and the board looks squeaky clean now, but even after that and restoring firmware and trying a few tricks online the back camera still comes up black and the flash wont work.
When i switch to video recording, the flash icon turns red and says the phone is too hot and must cool off for flash to work.
Any tips on how i can try and troubleshoot this problem? I have basic tools like a microscope but microsoldering is out of the question... No warranty either.
Absolutely any advice on either what component is likely the problem or what i can do or check to narrow it down would be greatly appreciated!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
My 6S Camera video recording front and back not working. Taking photos work. But when choosing to record everything seems ok but recording does not start. Tried a working front and back cameras but still not working. Anyone have a solution? ?
完成的
@dmd786 can you record a voice memo? Do you have any other audio issues?
完成的
添加一条评论
1个答案
已选择的解决方案
Well you will need microsoldering..
6s plus back camera has a filter between VCC_MAIN and LDO.
It needs to have continuity and providing 3.85-4.2V to the LDO.
The LDO must be outputting 2.85V.
All the connected caps must not be shorted to ground.
1V8 rail must be present on the camera connector and of course not shorted to ground.
Finally, you need to have tested with 2 cameras. Not just one. Or use a known good.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Daniel Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 256
