跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
How to remove epoxy resin on mainbaord?
I am trying to repair my mainboard but I can´t remove the epoxy just with hot air. I am afraid the resin under the BGA damage the pad when removing.
I try some solvents but it didn´t work.
Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
This epoxy, commonly referred to as "underfill" is used to secure an IC on the logic board. Phones take a lot of abuse, even if we don't always notice it. You would never think of throwing around other electronic appliances like we do with our phones.
The trick to removing underfill is patience and the right amount of heat. Underfill gets quite soft at ~220C. So if you have a hot air station, set it at low flow and 220C and start heating the chip. Then use a sharp scalpel or knife (or probe) and start picking at it. you have to be careful not to scrape the logic board or lift other components.
That's it...sadly. There are no tricks or solvents that I know that will dissolve the underfill.
这个答案有帮助吗?
得分 5
添加一条评论
H2SO4 will be helpfull.
这个答案有帮助吗?
得分 0
1条评论:
Sulfuric Acid... yeah be careful with that.
完成的
添加一条评论
添加你的答案
Giovani 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 1,601
