跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
External drive enclosure for MacBook internal optical drive?
Is there an external drive adapter that will work with the internal optical drive from a MacBook when I replace it with the "9.5 mm Optical Bay SATA Hard Drive Enclosure"? The drive still works. I have one of those testbed USB adapters that will probably work, but I would prefer a stand alone enclosure. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
I'd rather discard (maybe sell) the original slot-in drive and go for a standart usb external optical. The ultra slim drives in the MacBooks aren't very good and if you really need an OD youre better off with on off the shelf. I have a LG external that works wonderful.
这个答案有帮助吗?
得分 3
1条评论:
Thanks, I was thinking that, but I hate to waste anything that still works. ;-)
完成的
添加一条评论
Yes there are several options! The one I found cool is the following:
Easy to set, thin enough and cool looking!
http://eshop.macsales.com/item/Other%20W...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Sardior 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 3,416
