跳转到主内容
加入维修社区 - 创建账户
10.1" Android tablet released in June of 2011. Samsung GT-P7510MA
Kindle app won't open!
Since recent update, I'm unable to open my Amazon Kindle app.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Same problem except the app was on my phone. I forced stopped. Didn't work. I uninstalled it. When I try to download the app again it still says download pending. Haha! I was smack middle of an excellent book! Help!
完成的
Thanks... worked perfectly!!
完成的
添加一条评论
3个答案
已选择的解决方案
Go to Settings --> Applications (or Apps)
Find the Kindle app.
Click Force Stop.
Uninstall the Kindle app.
Download a fresh copy from Google Play store, and it should be fine.
这个答案有帮助吗?
得分 6
7条评论:
If i do this will i lose all my books i have paid for
完成的
You may have to download the books again, but you do not have to pay for them again. You can actually go to https://www.amazon.com/gp/help/customer/... to see all the books you purchased and make sure they are all in your account before moving forward. If you are missing books, you can complain to Amazon on missing purchase (I've had this happen before).
完成的
It did not work, I fgollowed yor instructions.
完成的
In that case, you may have to hard reset the entire tablet. Follow the instructions on this page, but make sure you back up your information such as photos and documents.
https://www.technipages.com/galaxy-tab-4...
完成的
@davidvila, no -- this is a tablet. And you need to warn about losing data. That's what a reset does.
完成的
显示更多的2条评论
添加一条评论
the above did not help in my case. i have a Nook tablet 7. my wife has the same device and the kindle app works fine, but on mine, it is either disappearing or keeps reporting a problem. have tried the above several times and a couple other answers i found thru google. it dawned on me that it could be the extra gb card i added to the nook. sure enough, i removed it, reinstalled kindle and it went into the built-in memory on the tablet, and works like a charm. reinserted the exrta memory and everything working fine. so it seems that app didn't like being put into the extra memory slot. seems strange as the other apps i have downloaded work fine with it.
just my 2 cents worth,
这个答案有帮助吗?
得分 4
6条评论:
OMG, that fixed it for me! Thank you, thank you!
完成的
This fixed it for me! Thank you!
完成的
Thanks so much. Worked like a charm!
完成的
Thank you so much! This worked.
完成的
@druhm that you your a life saver been disappointed for weeks
完成的
显示更多的1条评论
添加一条评论
Firstly, click on the kindle locked button to unlock your Kindle device
Then go to Kindle device setting and click to down and you get application manager so, find here your kindle app to uninstall.
After all these you can download new Kindle app from the play store.
Use your new kindle app with your Old Amazon Account.
这个答案有帮助吗?
得分 -1
2条评论:
1 tryed that;it didn't work.
完成的
I tried that it didn't work!
完成的
添加一条评论
添加你的答案
cathrynlynn7 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 31
总计 33,946
