跳转到主内容
加入维修社区 - 创建账户
The Kenmore Elite HE3 is 7.2 cu. ft. capacity electric dryer by Kenmore.
What is F 01 Error code?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
If you have a soldering iron and are a DIY person, this is a free fix - https://youtu.be/eWqrn5klxm0
My control board looked identical to the one in the video.
完成的
添加一条评论
2个答案
已选择的解决方案
The F01 indicates a failed electronic machine control board. This error code can sometimes be caused by a glitch or power surge through the electrical lines. You may be able to clear this code by unplugging the washer for 5 minutes. If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
You can order a new control board from the Sears PartsDirect website.
http://www.searspartsdirect.com/partsdir...
Here's how to do it: http://media.fotki.com/1_p,wkwdftgtbkdgf...
Be sure to unplug the washer before accessing internal components. When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time. Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer. Reassemble and test the washer.
这个答案有帮助吗?
得分 2
添加一条评论
I got F-01 on my Kenmore HE2. I took out the control board using instructions found on Youtube, but unlike the Youtubers, I did NOT have a blown solder joint. I racked my brains for what it could be. I decided to check the thermal fuse, which necessitated disassembling the dryer. When I did that, I saw that the belt was broken. So now the question is, did I have two problems (malfunctioning primary electronic control + broken belt) or just one problem (broken belt, fooling the electronic controls into an F-01 error code)? I called my local appliance parts store. They had a belt in stock for $25. I asked if a broken belt could cause an F-01 electronic control error, and he said he had never heard of that happening. This was a tough call because a replacement electronic control board is $150-$250 and the dryer is 10 years old. I decided to give it a shot replacing the belt. AND IT WORKED! Dryer seems to be fixed. There wasn't a problem with the electronic control board after all.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
feuder_kaldani 将永远感激不已
浏览统计数据:
过去 24 小时: 11
过去 7 天: 37
过去 30 天: 145
总计 25,461
