跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
changing the chasis cause "searching" no Baseband BUT yes IMEI
All the stuff I found in internet about no Baseband firmware is joined with no IMEI number
I have checked some cables inside but still thinking that maybe the flex interconnection between upper and lower side of logic board could be the cause
I've changed the dock and 3G antenna but without solution
I think that restore will cause a brick but OTA is not able to achieve because of the error during checking system in the iPhone
Could be solved UPDATING from iTunes? Afraid of not to be able to activate
Important to note that IMEI is still present but not network, searching with and without SIM inside
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Is there a modem firmware number in the settings??? Did you bend the board whilst you did the swap???
完成的
添加一条评论
1个答案
已选择的解决方案
You need to find a way to get the Lightning dock to connect to the frame to ground. I have a ...hold up... Scratch Brush That or you have lightning dock problems
Scratch Brush图片
产品
Scratch Brush
$3.99
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Alfonso 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 168
