changing the chasis cause "searching" no Baseband BUT yes IMEI
All the stuff I found in internet about no Baseband firmware is joined with no IMEI number
I have checked some cables inside but still thinking that maybe the flex interconnection between upper and lower side of logic board could be the cause
I've changed the dock and 3G antenna but without solution
I think that restore will cause a brick but OTA is not able to achieve because of the error during checking system in the iPhone
Could be solved UPDATING from iTunes? Afraid of not to be able to activate
Important to note that IMEI is still present but not network, searching with and without SIM inside
1条评论
Is there a modem firmware number in the settings??? Did you bend the board whilst you did the swap???
由 c9679 完成的
