跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2272 个问题 查看全部
Ripped one of the cables on LCD, but what is it exactly?
Hi!
I have disassembled an iPhone 7 but when taking of the screen one of the two flex cables from the lcd screen got ripped. The cable that got ripped runs upwards under the LCD part, to the top. The LCD and touch still work. (fun to know that the LCD and Touch both go through one flex cable). But it disabled the home button from working. I am trying to understand how the part that I broke runs underneath the hood and what I can do to solve it. Can somebody explain it to me with pictures where the cable runs to and how it works?
Updaten (04-05-21)
This is the Home Button cable. It’s very fragile for the iPhone 7 model. The solution is to buy a replacement screen. :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 15
添加一条评论
13个答案
最有帮助的答案
In this video I´m showing how to swap the backlight of an iPhone 7.
I had to do this repair because of the same problem,.... the cable was brocken.
VIDEO: iPhone 7 - Backlight, Home button, 3D touch repair
这个答案有帮助吗?
得分 6
2条评论:
I have cut the ribbon cable accidentally, I followed your video and I managed to replace the Backlight (mirror) as I have another broken LCD. The screen work perfectly fine but the touch stopped working totally with the TouchID. If I assemble the phone without connecting it to the motherboard. The touch function comes back but not the touchID. This is confusing and i hope you can assist here?
完成的
my home button is broken because i have a broken lcd but my screen wont connect to my phone at all i need help reply urgently
完成的
添加一条评论
That is the home button and 3D Touch cable.
There is nothing you can do to connect it back, but you can replace the entire display to make it work.
Currently there is a standing issue that some replacement screens do not work due to some issues of this cable/connector, but if you are careful and lucky enough, the replacement will work just fine.
Also,
DO NOT REPLACE THE HOME BUTTON.
USE ONLY THE ORIGINAL HOME BUTTON THAT CAME WITH YOUR PHONE
这个答案有帮助吗?
得分 2
3条评论:
Why shouldnt i change the original home button??
完成的
Because it won’t work.
完成的
if i just buy a new screen loaded with the ribbon cables and put my home button in that , will it work
完成的
添加一条评论
Remember the separate home connector cable on the 6 and 6 plus you could replace apart from the screen? This ran from the connector on the board, underneath the metal plate and to the home button flex itself. I'm assuming this is just that. Simply connects your home flex to the board itself.
这个答案有帮助吗?
得分 1
3条评论:
I've assumed that it was an Touch ID extension cable. I am just curious how it runs underneath the frame. I also can't seem to find a replacement part even though the ribbon cable was very easy to rip. Even Forbes ripped it; http://www.forbes.com/sites/aarontilley/...
完成的
On iPhone 6s/7, Touch ID cable is built into the 3D Touch panel. There is no way to replace just the cable, backlight plate or entire screen replacement is required.
完成的
what does it look like and what is it called when the cables 2 different sizes next to each oter called
完成的
添加一条评论
It’s 3D function of the screen
这个答案有帮助吗?
得分 1
添加一条评论
hi the ripped connector isn’t the LCD and Digitizer, if the LCD and Digitizer still works, then you have then ripped the Touch ID home button ribbon flex, if you replace the entire display assembly the home button will then work again, how i know is i had the same problem until i replaced the entire screen and mine is now fully working.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, this one is Touch ID cable, it can be replaced with complete backlight module and cost about $30
Here is a link to this unit on eBay
这个答案有帮助吗?
得分 0
添加一条评论
That cable appears to be the back light/home button flex. the back light has adhesive around the edges and can be carefully separated from the LCD and replaced but you will need to unsolder the contacts on the remaining flex cable to remove the old back light flex cable.
这个答案有帮助吗?
得分 0
添加一条评论
I am facing a similar issue(I guess), After a screen replacement my home button works fine, my screen works fine but there is something wrong with my 3D Touch, It just doesn’t registers a 3D Touch input(does not responds to my hard/firm press on the screen). Is there a way to test it ??
这个答案有帮助吗?
得分 0
1条评论:
There is a replacement button, yet you lose the Touch ID-function - I think you can not find a replacement button with it?
完成的
添加一条评论
I have Apple Pro Max Lcd with broken ribbon can you repair it .please reply urgently
这个答案有帮助吗?
得分 0
添加一条评论
I have iphone 11 pro max with broken lcd flex/ ribbon can you repair it please reply urgently
这个答案有帮助吗?
得分 0
添加一条评论
Hi, I have the same problem (iPhone 7, not the iPhone 11), and found a solution, I think. I still have to try it myself, so wish me luck! I’m buying these parts, since I can’t find the home-button cable on its own: https://www.etradesupply.com/apple-iphon... and will try to assemble it … Since this is an old thread, I might not respond to it further … Oh, see also Tom Chai’s reply from 2017 (higher up) - I don’t need the touch ID, just a basic home function.
这个答案有帮助吗?
得分 0
添加一条评论
The Part I assume is The Earpiece
这个答案有帮助吗?
得分 0
添加一条评论
mere iphne 7 key touch flex cut ho gye h
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Anthony 将永远感激不已
浏览统计数据:
过去 24 小时: 19
过去 7 天: 106
过去 30 天: 421
总计 71,137
