跳转到主内容
加入维修社区 - 创建账户
雪地摩托是专为冬季雪地旅行和娱乐设计的机动交通工具。其引擎通常驱动后部的连续皮带,推动车辆行驶,而前部的两只滑雪板提供方向控制。
Why is my snowmobile bogging
I have a1999 Polaris 600 xlt and I was running about 55 mph when I released of the gas and my sled lost a little power and was bogging out I lifted the hood and oil cap was off and there was oil in my air filter so I wiped all the oil up and it seem a little better buts still boggs out .I also changed the spark plug ran it a bit then my air filter blew a flame through it the sled drives just doesn't feel 100% what could be the problem
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
@lanny3 , Lanny, How well did you clean the oil in the filter box, did you replace the oil drenched filter as it could be clogged choking the engine, also make sure the clutch and belt are clean of the oil. There are a few things that could cause your engine to bog. Bad fuel, fuel line collapsing(pinched), clogged fuel filter,dirty carburetor, fuel pump failing, Carbs out of adjustment, bad plug wire, wires/plugs shorting out/loosing connection, weak coil/ignition box/CDI, wrong/fouled plug, vacuum leaks/bad crank seal, stick valve/reed, etc. I will post a link below to the service manual which may aid in your diagnosing and repair and a 2nd link to a forum diagnosing your issue. Good luck.
http://coodie.com/polaris/1999-Polaris-S...
http://www.snowest.com/forum/archive/ind...
这个答案有帮助吗?
得分 3
1条评论:
Ohm out spark plug caps (should be 4-5k ohms),pull a fuel sample let it sit for a couple hours & see if /or how much water there is in the fuel. Secondary clutch may have a broken button or the clutches all together may be dirty......There can be many seen and some not yet seen issues when it comes to troubleshooting snowmobiles I just threw out a couple for you -if they help at all.?
由完成的
添加一条评论
I totally agree with L Pfaff comment on problem-solving but I want to ask you one thing: how long have you changed the tracks of your snowmobile? If it's a long time ago, then you should probably change them to new ones, for example from the compositsnowmobiletracks company. I have been using them for several years and am generally satisfied.
这个答案有帮助吗?
得分 0
添加一条评论
My 750 touring Arctic Cat skidoo starts fine with choke...holds an idle well.After driving for extended time skidoo wont idle on its own when I stop. She just cuts out when I release the throttle. When I go to starter up again tbere is a clanging sound and I have to turn her over several times before it catches. When she starts up she won't idle on her own.. Shuts off as soon as I release throttle. I have replaced all the gas..added new gas with gas line antifreeze and fuel injection fluid. Also use seafoam to help clean carburetor. Put in new spark plugs and new battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lanny 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 43
总计 5,564
