跳转到主内容
The Samsung Galaxy S6 Edge+ is the larger variant of the Galaxy S6 Edge smart phone.
99 个问题 查看全部
Custom binary blocket by frp lock.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
gianimiliardaru0 exactly what does this "Custom binary blocket by frp lock." mean? what do you see? What does it do? It will help if you clarify this.
完成的
添加一条评论
4个答案
最有帮助的答案
Enable OEM Unlocking before flashing any ROM. Flash the Stock ROM and follow this guide to Fix Custom Binary Blocked by FAP or FRP Lock.
这个答案有帮助吗?
得分 2
添加一条评论
Greetings,
do you still have the problem, if yes I got the solution and also the bypass for you :)
Update (21.01.2018)
FRP Lock is used against thefts, before FRP exist, people could just do a three button combo to factory reset your phone and sing in with their Google Account. Since FRP it shall make it harder for people bypass this, if you do such a factory reset it will ask about the previous Google Account used (that clearly thefts don't have). Hope this helped you to clear it out. It is possible to bypass this.
这个答案有帮助吗?
得分 1
添加一条评论
Turn off reactivAtion lock first.
这个答案有帮助吗?
得分 0
添加一条评论
Heading text
fap lock
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
gianimiliardaru0 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 6
总计 3,046
