跳转到主内容
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Keyboard errors and trackpad failure
Internal keyboard function badly, and Trackpad stopped working after battery pack change. Keys to be pressed 2-5 times before it works. Hardware diagnostics gave error code 4MEM/9/40000000: 0x78fc6190. Help needed.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Most likely trackpad cable ripped when doing the battery replacement.
Anyway you should enter your MacBook serial number on the everymac website via its ultimate Mac lookup and post the correct model information so we know which MacBook it is.
For example MacBook Pro 15 inch 2013.
完成的
The model is MacBook Pro 15" Retina mid 2012. Trackpad cable also affect keyboard?
完成的
添加一条评论
1个答案
最有帮助的答案
That is a memory failure. Of course we don't know your exact model, could be a bad flash drive or if it uses removable RAM, try reseating it.
UPDATE
This is a very unusual error for this machine. The first thing I would do is take it in an have it checked for this issue as it might relate to your problem:
MacBook Pro Repair Extension Program for Video Issues
https://www.apple.com/support/macbookpro...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Tor Seim 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 7
总计 224
