跳转到主内容
The iRobot Roomba 4160 is an autonomous vacuum cleaner that vacuums both carpets and hard floor surfaces.
Roomba Runs for a minute and shuts off
Purchased new battery, fully charged, but only runs for a minute
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Does it make any noises when it turns off? Does it beep? If so, how many times does it beep?
完成的
No, it just stops. But it's working now! I unplugged it for a few months, plugged it back in to charge, and it works. No clue what happened. Thank you
完成的
Hello
Just replace the battery fully charged hit the clean button runs for a couple of minutes and it stops the status light shows up red and the clean button keeps on flashing green Thanks for your help
完成的
添加一条评论
1个答案
最有帮助的答案
RoombaQueen , Maybe try the battery reset procedure to see if that corrects your issue, you may have to repeat this procedure a few times. See link below on how to reset. Good luck.
https://www.youtube.com/watch?v=s7Lfg0KZ...
这个答案有帮助吗?
得分 2
2条评论:
Thank you GREAT video help
完成的
My 900 series will run for a minute then stop with 4 rising tones - battery is fully charged but its in a vacation home and the temperature is cold, could that stop it? its above freezing but prob in the 40's.
完成的
添加一条评论
添加你的答案
RoombaQueen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 10,597
