not able to make / receive calls
I have a new iphone 7 . I have inserted the existing SIM . But not able to make / receive calls . The SIM carrier is appearing in the settings . But on the home screen "searching" keeps on coming
If you can‘t connect to a cellular network or cellular data
Learn what to do if you see No Service or Searching on your iPhone or iPad (Wi-Fi + Cellular), or have cellular network and 4G LTE issues.
If you see No Service or Searching
If you see No Service or Searching on your device, or can't connect to a cellular network or cellular data, follow these steps:
Check your coverage area to make sure that you're in an area with cellular network coverage.
If you can't connect to a cellular network on your iPhone, make sure that cellular data is on in Settings > Cellular*. On your iPad, go to Settings > Cellular Data.
If you're traveling internationally, make sure that your device is set up for data roaming. Go to Settings > Cellular > Data Roaming.
Restart your iPhone or iPad.
Check for a Carrier Settings Update.
Update your iPhone or iPad to the latest version of iOS.
Take out the SIM card and put it back in. If the SIM card is damaged, or doesn't fit in the SIM tray, contact your carrier.
Reset your Network Settings. Tap Settings > General > Reset > Reset Network Settings. This also resets Wi-Fi networks and passwords, cellular settings, and VPN and APN settings that you've used before.
If you have another device, see if you can connect your carrier's network with it in that location.
Contact your carrier to:
Verify that your account is active and in good standing.
Make sure there are no outages in your area.
Check that your device isn't blocked from receiving cellular services and is set up with the right data plan.
If you still can't connect to a cellular network, and have confirmed with your carrier that there isn't an issue with your account or network, try restoring your device.
Hope it Works
Thanks
Varun
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 399
