跳转到主内容
加入维修社区 - 创建账户
Formally called the Chevrolet C/K, C/K is a series of trucks manufactured by General Motors and marketed under the Chevrolet and GMC brands. The C/K line includes pickup trucks, medium-duty, and heavy trucks.
Brake light stop working
Brake light stop working on my truck i put a fuse in it and hit the brakes and it blew put other one in and it done the samething what do i do
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Hi, Does it only happen with the brake lights or do you blow a fuse with the tail and turn lights as well?
Have you got trailer wiring connected at all?
完成的
添加一条评论
1个答案
最有帮助的答案
Patricia Holloway, If your brake light fuse is blowing every time you press the brake pedal there is a dead short in the brake light circuit between the switch and the bulbs. The wire harness must be traced to find the short. Try a visual inspection, you will be looking for any damaged,bare,pinched,burnt(melted insulation) on wires,plugs,sockets and also check/test bulbs. Pay special attention to any where wire could be rubbing on metal frame, taped up joints/connections, etc.. If there is a trailer light harness with converter, especially if a add on one you may want to disconnect it as they can be problematic and cause this issue. If not comfortable working on your vehicle take into a good shop and have them diagnose and estimate repair, most good shops have hand held short finders(link below) and can find the problem fairly quickly. Good luck.
https://www.youtube.com/watch?v=ufVuWznm...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Patricia Holloway 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 88
