跳转到主内容
加入维修社区 - 创建账户
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
help me I need help
my screen wont turn on anymore how can i get it to turn on
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
@killerclownson ,nathan eastman , Make sure your device is charging or fully charged, try a different charger or cable if not sure it is charged or charging. You can try and hold the power button and volume down switch, a android logo should appear, then go into menu and select boot normally. Below are links that also help in getting your device to power up. Good luck.
http://www.tomsguide.com/forum/id-207915...
https://www.quora.com/How-do-you-reset-a...
这个答案有帮助吗?
得分 3
1条评论:
it might work i have problems
完成的
添加一条评论
添加你的答案
nathan eastman 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 4
总计 110
