跳转到主内容
为iPhone 6s 设计的充电后壳,由Apple在2015年12月发布。Smart Battery Case包括一个一体的电池来增长iPhone 6s的电池续航。
11 个问题 查看全部
Do you sell the replacement battery for this case?
My battery on the iPhone was completely dead and basically relying on the case's battery, then I ordered new battery for iphone on ifixit and replaced it, now the case wont even charge and is basically dead, there a particualr battery for it that you sell? The replacement looks relatively easy/.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
2个答案
已选择的解决方案
Hopefully this is still under warranty and you can get it replaced by Apple.
The teardown states:
"Battery replacement is possible, but will likely destroy the microfiber liner.
The only possible repair—replacing the battery—is made difficult by very strong adhesive."
这个答案有帮助吗?
得分 4
4条评论:
Yeah, I bought this case when it was released, needed the lightning connector that the mophie didnt have so I could use my carplay without removing phone each time. Purchase date was Jan 31st 2015 so I doubt its still under any warranty. Also, it only looks that I would mess up the interior felt lining which is hidden by the phone anyway, so it wouldnt really be a big eyesore, just getting the battery out from adhesive would be the most difficult.
完成的
I use a high grade alcohol (methanol) and a syringe and shoot it under batteries to loosen the glue. Works well on MBP glued in batteries.
完成的
this answer isn't helpful at all.. what is the type of battery and where can you buy it?
完成的
This answer isn't helpful at all.. what is the type of battery and where can I buy it?
完成的
添加一条评论
I’m in the same boat, i have an 18650 laptop cell soldered to the the board of the apple battery to test and the smart case works and charges………………………………….but i cant seem to find a similar capacity battery of the proper dimensions, i dont even need an apple battery, i have the apple batteries connector desoldered and ready to be used w any battery i just need one that matches the dimensions of the case
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christian Postier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 15
总计 1,542
