跳转到主内容
加入维修社区 - 创建账户
型号 M4753 / 233、250、266、292 或 300 MHz G3 处理器
System Recovery PowerBook g3 Series
Hi!
I have PowerBook g3 Series. m4753
Very old version, I know. But I likke the classic.
When I turn it on, it uploads. But after I see white screen with a diskette and a question mark inside. After 1-2 min, it turnes off. Also when the question mark is on my screen, i hear little scratches. Not so loud, right side but not CD.
If you could help me please, thank you.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Not good ;-{
Your hard drive has failed! The scratching noise is likely the head assembly rubbing on the disk.
You'll need to find a replacement drive which will be hard as the drive is an older PATA unit (IDE). Once you get the drive out you should be able to search for a replacement using the make and model info on the drive for an exact replacement. Finding one new will not be easy, more likely to find a used one.
Here's the IFIXIT guide you'll need to follow to replace it: PowerBook G3 Wallstreet Hard Drive Replacement. In addition, you'll need to find a copy of the older Mac OS-9 on a CD to prep up the replacement drive if you still have the grey disk that came with your system you'll be all set otherwise you'll need to hunt down a retail version of the software on eBay.
这个答案有帮助吗?
得分 2
1条评论:
Given its age it's a nice show piece if it's not worn (collectible). If you are planning on using it I would recommend you put your pennies into a newer model (new or used)
由完成的 分享
添加一条评论
添加你的答案
YanC 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 556
