跳转到主内容
A rechargeable, cordless beard trimmer created by Philips. The model number is QT4000/42.
7 个问题 查看全部
Why is the blade making unusual noise and stopping after a few seconds
Firstly where shud the spring ends be placed while reassembling the parts
And the trimmer is making unusual noise and stopping after a few seconds
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Siddhant dhandhania , Make sure the head is clean and undamaged,try lubricating blade very lightly, ensure assembled correctly. If all looks good and still stopping after a very short time batteries could be worn out or motor may be on it's way out. If still under warranty use it for replacement/repair/refund. Use the link below to aid in blade installation. Good luck.
Philips Norelco BeardTrimmer 3100 Blade Replacement
这个答案有帮助吗?
得分 4
添加一条评论
i get this on mine, its usually Jammed. i lucked out and baught a water proof model. so i just run it under the tap, and its good to go. i know this probably doesnt help, but its better to try before replacing it.
这个答案有帮助吗?
得分 1
2条评论:
I have just replaced the new set of blades. After some initial 5-6 shaves, this problem has started. Even after cleaning the three rotors under fast tap, the problem refuses to go. Can you suggest some other solution please?
完成的
try cleaning it and then add some oil inbetween the blades if you havent done that yet
完成的
添加一条评论
添加你的答案
Siddhant dhandhania 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 49
总计 6,326
