跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
What can I do to fix a rough SuperDrive eject?
I recently installed new superdrive and the eject seems a little rough and the CD isn't being fully ejected. It's only being ejected 2".. what can the problem be?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
7条评论
So this would be a continuation of your earlier problem (the malformed drive)?
完成的
yes but the drive has its original topcase now. i had the edges machined down so the 868A can fit into the macbook. The malformed topcase was from my old superdrive. The problem was that the new superdrive did not fit due to the protrusions on the corners. so i temporarily switched the superdrives topcase with my older one which was deformed. This caused an awkward eject. Now that i put the new original topcase the eject is parallel to the machine but rough and not fully ejecting
完成的
Rab would u feel comfortable giving me your email address so i cand u a pic of the eject.?
完成的
No need, you can upload a pic to your question, do you need to be shown how?
完成的
please QE
完成的
显示更多的2条评论
添加一条评论
6个答案
已选择的解决方案
If you haven't yet opened the drive do so and check that the protective felt on the left side of the drive is not lose or wrinkled. If it is re-glue it securely.
Good Luck,
N.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I think that this is down to the drive you installed rather than the macbook itself, you could try putting the drive in another computer to see if it does the same. If it does you can either live with it or get a new drive that works better.
这个答案有帮助吗?
得分 1
2条评论:
Its a new drive, i ordered direct. not ebay.
完成的
I didn't say you bought it off ebay, it could still be faulty brand new.
完成的
添加一条评论
Towards the end of the eject theres almost a hesitation and studdering sound.
这个答案有帮助吗?
得分 0
3条评论:
ooops, its in the wrong field but u get the picture. Thats not a full eject.
完成的
Can you pull the disc out or is it still held in by the drive?
完成的
I can pull it out but its tougher than it used to be cause i cant grip the cd, then i have to put a little extra force to insert or pull the cd out.
完成的
添加一条评论
Does the drive attempt to push the disk fully out? (does the motor spin even when the disk doesn't come out?)
这个答案有帮助吗?
得分 0
2条评论:
yes it does, it makes a funny sound then stops.
完成的
When it gets the distance shown above it gives a extra push and makes a funny sounds then stops. When insering the cd the first half of the cd goes in just fine but the second half of the cd i have to push it in with a little force before it passes a certain threshhold then the drive takes it in.
完成的
添加一条评论
Maybe you could try taking the drive out, and putting it back in, there's a chance you put it in awkwardly or slightly disoriented.
这个答案有帮助吗?
得分 0
添加一条评论
Thanx for the suggestions guys. Will remove and reinstall and check for any abnormalities.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Majesty 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 1,301
