跳转到主内容
iPad Mini 4 发布于2015年9月9日,有着类似 iPad Air 2 的性能和更小巧的身材。
176 个问题 查看全部
Sleep button not working
Hello there,
Just got an weird issue , i repaired an ipad mini 4th gen. everything works well except the sleep button wont work.
but it does work as power on/off .
i Know what most gone say now:
Bad digitizer , Nope tried 3 screens
tested screens on other ipad mini 4 and their it does work.
any had this problem to?
would love to hear how you solved this.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Transfer the Hall effect sensor, it's a small component near the home button. Without the sensor the machine asserts the cover signal as attached so the sleep/wake function is completely latched. The power button cannot be used for sleep/wake in this situation, only power off works.
这个答案有帮助吗?
得分 2
2条评论:
is there guide for that? How is it done?
完成的
i know what you mean , but what if you trow it away already? can it be ordered ?
完成的
添加一条评论
添加你的答案
briiangullentops 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 1,235
