跳转到主内容
加入维修社区 - 创建账户
A Kenmore residential washing machine made between 2001 and 2009. Identify the age of your Kenmore washer with its serial number.
The machine won't turn off. It goes through the cycle again
The machine won't turn off, when it is done spinning it immediately starts filling again and goes through the cycle again and again.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I have to manually stop the washing cycle and then put on spin cycle and manually stop it also. It won't go to the next cycle on its own.
完成的
添加一条评论
1个答案
已选择的解决方案
@barbeblom , Barb, sounds like a bad timer/control board allowing washer to keep cycling. Check the video below for more about a washer's timer function. You could try a google search using your make and model #. If not comfortable working on your appliance, have a good repair Tech. have a look, diagnose and estimate repair.Good luck.
https://www.youtube.com/watch?v=7STcI9xw...
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
barb blom 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 5
总计 9,203
