跳转到主内容
加入维修社区 - 创建账户
Bezel cracked, display jumpy
The bezel on my wife's 2007 15-inch Core2Duo MacBook Pro has a crack just above the base on the right side. The display jumps a little. It doesn't flicker. I need some informed speculation before I try to replace anything. The jumpy display suggests some electronics or wiring is bad, but not necessarily that the display itself is bad. If I tackle this, what parts would probably see me through? Bezel. Wiring? Display?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
That models display frame usually breaks on the left side about an inch up from the bottom left hand corner as you are looking at the machine. @mactech has repaired a few of these and is better qualified than I to give you a comprehensive answer.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
bobball 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 169
