Replacing Hard drive iPod Classic 60 Gb
iPod Classic 60Gb Model A1099
If I replace the hard drive in my 60Gb iPod Classic with a 240GB Toshiba MK2431GAH hard drive, do I follow the same directions as the standard hard drive replacement?
That drive should work. Here's how to do it:
iPod 4th Generation or Photo Hard Drive Replacement
Here's how to do it: https://www.youtube.com/watch?v=dYZqTvlT...
这个答案有帮助吗?
Yes-as long as it's the same connection (which it is), it will work. But if you haven't bought that drive already, I recommend this: https://www.amazon.com/Samsung-850-EVO-I... + https://www.amazon.com/SMAKN-mSATA-PCI-E...
这个答案有帮助吗?
This drive solution is far cheaper and reliable than that HDD.
Yes, assuming the connector is the same on both hard drives, and that it is compatible with the iPod (some of them have a limit as to how much memory they can see).
You might also consider replacing the HDD with an SD card, I've done this myself recently and it makes a noticeable difference. This is the shop I bought the kit from:
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 11
总计 1,002
1条评论
Do you have the fat or thin drive?
由 mayer 完成的
