跳转到主内容
The C720 is a low cost Acer ChromeOS based Chromebook. Released 2014 successor to the C710.
26 个问题 查看全部
Just Rebooted Laptop keeps showing acer title in repeat doesnt startup
Rebooted my pc & it gets as far as acer title the screen turns black as if its loading then repeats the title... then you think somethings gonna load but it doesnt repeats acer title it wont start up... can this be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Need to know if you get beep codes ? If you get beep codes it's a hardware device if not it's usually a memory card or HD . Look up beep codes on web to check how many beeps mean what . A single beep is what you want . Also did you install new hardware if so take it out . Did you change anything ? Did you drop it . Need more info
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gonzalez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 123
