service engine soon light
how do I reset' Service Engine Soon' light
@scull801 , Steve, Turn ignition switch to on without starting the engine. Press the options button on the instrument panel until the service light is displayed, then press reset/set button to show the reset confirmation screen.
Turn ignition off. Repeat if message comes back.
Use the links below for more info.. Good luck.
https://www.youtube.com/watch?v=FF9e44tQ...
这个答案有帮助吗?
The "Check Engine" or "Service Engine Soon" light indicates there may be a repair or replacement of your engine or transmission. It means there is more than a routine repair or service requirement, and instead, a system failure to the fuel, transmission, ignition, or emissions.
这个答案有帮助吗?
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 49
总计 18,217
