2012 MacBook Pro stopped working
Ok I've got this 2012 MacBook Pro that somewhat turns on, fan runs heavy, battery seems to be charging (charger leds and battery leds work), front led lights up but laptop doesn't chimes and screen keeps black.
Screen has no cracks or scratches, laptop wasn't water damaged or impact damaged.
I cleaned everything with isopropyl anyway: all contacts, whole logic board (both sides), replaced thermal paste, etc.
Also tried 3 different sets of 2x2gb ram and 2 different HDDs too.
Disconnected battery and tried turning it on with charger only (60w charger). Also considered replacing battery but if it doesn't work with charger only (battery disconnected) might rule it out? :-)
Oh and it doesn't boot from USB, doesn't boot on safe mode or verbose mode. But took a DVD in and seemed to run it but now won't eject it (it was a movie DVD instead of OS X DVD unfortunately)
To be honest I did it all very quickly and plant to have another look tomorrow after work but has anyone got any ideas you might suggest me to try? I feel this laptop is salvageable but I'm feeling a bit lost here :P
Any suggestion would be very appreciated :-)
Thanks!
Connect a monitor to the computer to rule-out dead LCD. Sounds like possible GPU failure.
由 Dane Johnson 完成的
Thunderbolt digital video output
Native Mini DisplayPort output
DVI output using Mini DisplayPort to DVI Adapter (sold separately)
VGA output using Mini DisplayPort to VGA Adapter (sold separately)
Dual-link DVI output using Mini DisplayPort to Dual-Link DVI Adapter (sold separately)
HDMI audio and video output using third-party Mini DisplayPort to HDMI Adapter (sold separately)
由 mayer 完成的
I have the exact same issue and no solution
由 Samir Beuse 完成的
