跳转到主内容
加入维修社区 - 创建账户
Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
Hard drive replacement recognition
Just replaced the HDD with a known working one. It is not being recognized.
When I start up from a dock unit has no problems, but does not show the newly installed drive. Unit works fine from the external dock (drive).
I have apple service manual and have viewed you replacement video. From what I can tell the drive is properly installed and everything plugged in properly. So what am I missing, or where should I be looking?
Not my first rodeo… and as you know these units are a bear!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Looks about this vintage:
Apple iMac "Core 2 Duo" 2.16 20-Inch Specs
Identifiers: Late 2006 - MA589LL - iMac5,1 - A1207 - 2118
The drive has to be formatted. Boot up from your original system installation disk, go to the second page pull down menu to Utilities > Disk Utility and format it. Then install a system.
这个答案有帮助吗?
得分 3
8条评论:
Carter here, I am sorry perhaps I was not clear enough about the facts.
The drive is already a formatted, loaded working drive (one pulled from my Mac Pro). It is not a formatting problem nor a system problem. it is a hardware snafu, and the drive is properly "plugged in". (I have formatted and installed hundreds of drives)
完成的
The drive may not be backward compatible. What drive are you using? Did I get the correct machine?
完成的
Yes, you have the right machine. It is not about the drive's compatibility,it will work from my external dock. Better odds in the wiring or another unseated plug, or, or, or…..
完成的
Did you put a system on it?
Pre-Installed MacOS: X 10.4.7 (8K1106) Maximum MacOS: X 10.7.5*
What was going on with the old drive?
完成的
I used a working OSX 10.7.5, I am not sure about the old one. It has been in storage for a few years. That being said, the iMac works just fine when it boots from my ext. dock. Again, it is not about the 'drive', it is about the rest of the unit. (i.e. wiring, plugs etc.) As I have it back together now (except for the 'cover', I would pose the question before removing the screen and such and therefore know where to focus my search.
完成的
显示更多的3条评论
添加一条评论
添加你的答案
Carter 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 260
