MacBook Pro won't go past login screen Recovery/Ext boot won't work
Everytime I get the same, it gets stuck on the screen right after where the desktop should go up. Usually white screen, but also blue screen and also blue screen with black vertical lines. Running out of options...
Recovery mode won't work, external boot drive won't either. Always get stuck after the apple logo screen. Tried Internet Recovery, same result. When entering Target mode I can access the HD ok, so I made a backup in case. Hardware test mode works, tried both test modes, says everything is fine. Took it apart, removed on of the RAMs, tried both by themselves on both slots just because, again nothing. After some search I found that it could be a GPU issue, but shouldn't the hardware test pick it up? Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
If you plug in an external monitor, does that work? That will rule out a GPU issue
完成的
Which 13" MacBook Pro do you have? What OS X?
完成的
添加一条评论
