跳转到主内容
Repair and disassembly guides for HP printers.
1090 个问题 查看全部
How to change cartridge of HP J4580
How can I change the cartridge of HP J4580
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
4个答案
已选择的解决方案
Here is a link on replacing cartridges in your HP.
http://www.ehow.com/how_6653646_change-c...
这个答案有帮助吗?
得分 1
添加一条评论
Solution of HP printer cartridge Issues
1. In Windows . Select Start.
2. Select Printers & Faxes (or open the Control Panel and select the Printers & Faxes folder)
3. Select your HP printer.
4. Click FILE on the top right corner and select Printing Preferences from the pull down menu.
5. Select Advanced Options Tab.
6. Click on More Options.
7. Select one of the following two options.
a. Never Display the print status
b. Display the printing status minimized in task bar.
8. Press OK, Press OK, and close windows.
这个答案有帮助吗?
得分 0
添加一条评论
Steps to replace the cartridge of HP OFFICEJET J4580
  • Open the access door of the cartridge until it latches to its position.
  • Once it reaches to the center of the position, remove the empty cartridge or the one you want to replace from its slot
  • Open the new cartridge, remove the plastic tape from its head.
  • Put it into the empty slot. To make sure it is correctly installed, push down until you hear a click.
  • Close the access door
Found these info from WorkAroundTC
That's it :)
这个答案有帮助吗?
得分 0
添加一条评论
At first you need to open the door of the cartridge. After that you need to remove the empty one (that one you want to be removed). Furthermore, remove the new cartridge and remove the plastic from it. In the end, place it in the empty slow and press until you notice a sound similar to short click. Finally, close the door and you are done. In case you are getting any errors you can run HP Printer Resetter and reset the printer back to its defaults. After that, all errors should be eliminated.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Amado Petallana 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 10
总计 2,082
