跳转到主内容
A large smartphone by LG, released in fall 2014. The LG G3 (D855) boasts a Quad HD IPS display and a 13-megapixel camera.
180 个问题 查看全部
Why won't cables fit my ports after phone was dropped in water?
I dropped my phone getting out of a vehicle last night, during a pretty heavy rainstorm. I looked for it for about an hour before I found it, facedown in a puddle. I carried it in, but bumped the screen, and it came on. (It was in a protective case, but not anything water-resistant, like an Otterbox.)
Everything worked, other than thinking that a device was plugged into the headphone port. Per an online search, I used a can of compressed air to blow out the port, and that icon went away.
Everything seemed fine, until I tried to plug my charger in. The cord would not fit. Same thing for the headphone jack. Any ideas on how to fix this? (Or clean it, in case mud is in there.)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You can try cleaning them out with isopropyl alcohol and a toothbrush, if that doesn't work then you probably need to replace the ports. The headphone jack is easy as it is modular so you can just pop it out and install a new one.
Follow this guide up to Step 9. LG G3 屏幕更换
The charging port on the other hand is soldered onto the board so that would require soldering equipment and knowledge to desolder the old part and install a new one.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jamie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 2,599
