跳转到主内容
加入维修社区 - 创建账户
The 1999 Chevrolet Malibu is part of the fifth generation (1997-2003) manufactured by General Motors. This is the first smaller, front-wheel-drive Malibu that General Motors put back on the market after the Malibu line was temporarily discontinued in the early 1980's.
no tail lights, and no dash lights
I have a 03 chevy malibu with no tail lights, and no dash lights what's wrong with it any suggestions?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
I'm having a problem with my 2003 Chevy Malibu tail light don't work but everything else work. Any suggestions.
完成的
添加一条评论
3个答案
最有帮助的答案
Vanessa Cauley , check taillight/park light and instr. light fuses with a test light rather than visually as this will test fuse and connection.
15 Amp PARK LPS fuse in your under hood electrical center, if it is blown and you change it and it blows again, my suggestion is to remove (both) of your rear lamps on the vehicle and unplug them. Then put a new 15 Amp Park Lamp fuse in the under hood center and turn the lamps on again. See if the fuse blows. If it does not then plug in each lamp individually and see which rear lamp causes the fuse to blow. This will help trouble shoot which socket,plug,wires to be checked, causing the issue hopefully. See links below that also trouble shoot this issue and have useful info. and suggest test to try. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://www.automotiveforums.com/t247186-...
http://www.chevymalibuforum.com/forums/6...
这个答案有帮助吗?
得分 3
添加一条评论
You probably just need to change the bulbs. It's very easy.
这个答案有帮助吗?
得分 0
添加一条评论
Maybe check for dead fuses
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Vanessa Cauley 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 38
总计 4,385
