跳转到主内容
发售于2016年9月16日。型号为1660、1778。有 GSM 或者 CDMA 网络制式可选。提供32、128或者256GB 的存储空间。提供玫瑰金色、金色、银色、黑色和亮黑色。
2244 个问题 查看全部
Would it technically be possible to add headphone jack to iPhone 7?
1. I know there is some Lightning to headphone adapters that split the connector into a Lightning port and a headphone jack. Is there enough empty space in the phone (or enough empty space from removing something not necessary) to add a headphone jack and the chip from one of those adapters?
2. Would it be possible to then de-solder the Lightning port and solder the adapter to it, then re-add the port connected to the adapter?
3. If possible, how hard would it be?
If it isn't possible with the normal iPhone 7, what about the 7 Plus?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
There is zero "extra space" in the iPhone 7.
完成的
添加一条评论
2个答案
已选择的解决方案
Ehhh I mean technically way on the outside, it's possible. But you couldn't really desolder the headphone jack, exactly, technically it's a press solder onto a ribbon cable. So you'd have to somehow build a custom ribbon cable to fit an extra jack. So it's not really possible, and no there really isn't any extra room, and no it wouldn't be possible with a 7+. I appreciate the thinking outside the box, however it would just be really difficult
这个答案有帮助吗?
得分 3
添加一条评论
Everything is possible, but You have to project your own iOS, lightning flex, and PROBABLY new paths on maiboard :)
You can do it, it only depends of that, how rich you are, and how smart people you will ask for this.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Arie Copley-Radder 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 171
