跳转到主内容
Also known as LG Cayman, LG Optimus Exceed, this CDMA Verizon smartphone was released April 2012 with Android 2.3.6 (Gingerbread).
7 个问题 查看全部
Why won't my LG VS840 Phone power up?
When I plug my phone in to charge...as soon as I plug it in, screen lights up first with LG logo then shows my battery is fully charged. Then screen goes black. When I try to power up by depressing power button, it will not come on. I've tried to take battery out then back in and same with my sim card. I've tried double clicking the power button, long depressing power button and just a single push it on. There is no phone protection case so nothing interfering with power button. Have not used the phone in 2 or 3 years but never any damage...always in protective case and screen protection. No water damage or dropped.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
最有帮助的答案
@creolesue "not used the phone in 2 or 3 years " start with a new battery. It is possible that you battery just no longer holds a charge which is pretty common for batteries that have not been used for a while.
这个答案有帮助吗?
得分 3
添加一条评论
hi i tink there is a battery problem is there can u change battery and try... or else power button issue is there replace the power button and check
这个答案有帮助吗?
得分 2
2条评论:
The batter seems fine. When I plug in the charge...it says that it is fully charged. Then goes back to black.
完成的
I have the same exact problem. Frustrated with Verizon for not being the least bit helpful! I'm hoping it's as simple as replacing the battery. But I have no idea what they cost.
完成的
添加一条评论
添加你的答案
Sue Plaisance 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 11
总计 563
