跳转到主内容
加入维修社区 - 创建账户
LG的旗舰智能手机,具有独特的滑出电池和可拆卸的I/O模块,支持多种硬件扩展选项。发布于2016年4月。
Why my touch screen not working?
Hi , my phone was dropped into water about 5sec and immediately jump out the pool, i get out the battery and put into rice. After desoxidation i turn on and screen working as well, but touch screen not. I bought another screen, but the problem still there. So i picture my board and zoom in.
Can someone help me ?
EDIT: touch screen work immediately right when i turn the display on and he becomes a little crazy and stop working.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Hey, I had the exact same issue. Dropped the G5 in the water for like 2 seconds and then dried it for 72h. The display is working but the touchscreen is broken so I bought a new display (LCD + digitizer) and, like you, it didn't solve the problem...
Have you found a solution ??
Thanks a lot
完成的
i have the same problem but the mother bord is clean... you have a solution? lucas
完成的
2021 I still got the problem, no amount of cleaning works.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi,
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but does nothing to fix the problems caused by corrosion.
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ to remove all traces of corrosion and water. The effects of the corrosion will continue until the pcb has been properly cleaned. Do not use "rubbing alcohol" as in some cases this is only 70% and is not as effective. If you do check the label to verify the amount
Here is a couple of link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your phone.
LG G5
If this process seems too daunting, take your phone to a reputable, professional phone repair service and ask for a quote for a repair. If you decide to do this, do it sooner than later.
这个答案有帮助吗?
得分 2
1条评论:
Thx a lot for your time here ! But my doubt is about this specific part of my board.
Again, thx for now.
完成的
添加一条评论
添加你的答案
lucas_nalii 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 11,541
