Tranny stuck in reverse
How to take it out of reverse
@jpnegron , Sergio Angulo , If manual transmission, try having some one rock the truck back and fourth while you try shifting out of reverse. If it does pop out your clutch/pressure plate/master/slave cylinder may be worn/faulty/ or have air in hydraulic system not allowing release. If it will just not come out of reverse suspect a damage/bent shift fork inside tranny. Good luck.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 16
总计 453
