跳转到主内容
加入维修社区 - 创建账户
How to replace ssd
Aspire A0A 111
How do I replace de 8Gb SSD with a 16Gb SSD?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Could you please give us some more information about the model?
完成的
I'd give you a plus one right now if I could, kiddo
完成的
添加一条评论
1个答案
已选择的解决方案
I believe this is a 1.8" zif SSD. This tutorial from 2008 may help. However, there may be more modern ways to adapt a higher capacity drive using an SD card, SD to compact flash adapter, and a compact flash to Zif adapter.
https://tnkgrl.com/2008/08/16/modding-th...
这个答案有帮助吗?
得分 2
6条评论:
If it truly is a zif, I would recommend getting a msata SSD and msata to zif. I own an aspire one and it uses a regular HDD. Depends on model.
完成的
I agree with George if the budge is no issue. SD cards are dirt cheap, but MSATAs are still a bit high in price. And capacity vs price is what you should decide on. It is very possible and cheap now adays to go beyond 16gb.
完成的
Let's put that into perspective:
64 GB msata+adapter=$50
64 GB SD+adapters=$40
120 GB hard drive=$55
The SD card would have about the same read/write as the HDD or the current drive. The SSD would have 5x better speeds, be more reliable, and only slightly more expensive. A SD card wouldn't make much sense, because for $10 Dollars more you can a much better SSD, and for $15 more you can get double the capacity with the same speed as a SD.
完成的
You can believe me, I did alot of research trying to upgrade a zune with 1.8" zif HDD.
完成的
I am not sure about your point on reliability. I've had more SSDs go bad than SD cards. Moreover, Sandisk (now owned by Western Digital) offers lifetime warranty on their high end SD cards and CF drives vs a max 5 years on other products such as SSDs. I have yet to get a real person to talk to me at Samsung for the EVOs (I had 2 go bad). Sandisk's replacement is far less of a headache if things do go south.
https://www.sandisk.com/about/legal/warr...
完成的
显示更多的1条评论
添加一条评论
添加你的答案
gtdiller 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,043
