跳转到主内容
The NutriBullet by the makers of Magic Bullet is a personal blender that is self-contained and simple to use. It includes an electric blender base with a number of attachments for the user and offers a healthy alternative to blending food by breaking down ingredients in their most nutritious states.
65 个问题 查看全部
How do I replace the center plastic circle part that the blade attache
The center plastic circle that the blade and cup attaches to in order to begin spinning, broke off and I ordered a new part. That part needs to be threaded onto the centre motor piece, how is that done? That center nut and screw must undo correct?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
已选择的解决方案
mahcyb , The video links below will show how to remove the plastic drive wheel on your Magic Bullet and replace it(take note the threads are back wards to most, turn right((clockwise)) to remove/loosen) and anti clock wise to tighten on re assembling new drive disc. Good luck.
https://www.youtube.com/watch?v=Nz0yykNk...
https://www.youtube.com/watch?v=SBrNyGVn...
https://www.youtube.com/watch?v=L-yK0JE4...
这个答案有帮助吗?
得分 4
4条评论:
Excellent Instructions! Thank You!!
完成的
Yes but still cant get the screw of
完成的
The plastic piece broke off and left the screw that held it on it is that wont move I hace taken it apart and have accsess to main stem it fits on bbut it want move
完成的
If you have any access to a dremel and can put cut off black wheel on it. You can cut a slot for a large flat head or standard screw driver. Spray anything Pam, cooking what ever you have. Penatrating liquid is the best. I like (Free All) from Orileys Auto Parts. Remember to let it work for you first. And final I have heard that some of the screws are reverse thread.
完成的
添加一条评论
添加你的答案
mahcyb 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 22
过去 30 天: 58
总计 14,525
