跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。型号为A1532, A1456
Sometimes problem touch screen
Hello, I have a problem. My 5 c works perfectly then sometimes stop taking certain keys. If I rotate horizontally then I put it vertically, it works, then after a few days the problem occurs again, I tried to mount another original display but the problem sometimes recurs. Not even a tweet in dfu mode solves the problem
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
9条评论
I disassembled the original one from an iPhone.
完成的
Was the phone dropped or liquid damaged? Was there some type of impact to the phone before this behavior started?
完成的
No liquids, the phone did not have a big impact.
完成的
Luca, this issue sounds like a digitizer issue. Have you done replacement of screen on your 5c? If so what kind of screen did you put on it? Some screen manufacturers make cheap screen that barely work.
完成的
I might try doing a reflow at ic
完成的
显示更多的4条评论
添加一条评论
1个答案
已选择的解决方案
Since you tested with a different known good screen, it is now safe to say that your iPhone is suffering from a "touch" disease very common to all iPhones with a soft shell, and to a lesser extent to other iPhones with a hard shell. Just google "touch disease iPhone."
Soft shell iPhones would be: iPhone 5C, iPhone 6, iPhone 6+. The latter two models suffer from it the most. We see and fix a lot of them. Probably the most recurrent repair lately.
The repair may be simple if the damage is only on the display circuit, or more complicated if the touch ICs themselves are separating from the board. Either way, it is likely that the problem will increase until the screen becomes completely unresponsive. And either way you will need a microsoldering technician to fix it for you as this is not a DYI type of repair. You need proper microsoldering tools and skill other wise you risk ruining it completely.
这个答案有帮助吗?
得分 5
9条评论:
Not to disagre but I wouldn't jump to touch ic just yet. Very possible but I always suggest check your physical digitzer connector first then move to touch ic. If touch ic doesn't fix then move to chestnut ic. Great answer also Rany!
完成的
Hence the "display circuit."
完成的
Do you mean touch circuit? Display circuit would follow backlight and chestnut. Also you know ics are apart of a circuit right?
完成的
touch is powered pp5v7 and pn5v7 from lcd pmu lcd powers touch
1st test supplies before removing any ic also trackpad ic has a driver so the supplies to this are primary to test
完成的
This is not a pro forum. This is a DYI forum
. When I say display circuit, I mean it in the general sense: 2 connectors, chestnut, caps, filters, resistors that all make up that circuit and may totally or partially fail.
完成的
显示更多的4条评论
添加一条评论
添加你的答案
Luca Ciclisti 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 25
总计 470
